Автор Тема: Синклинальная нефть  (Прочитано 23312 раз)
Re: Синклинальная нефть
« Ответ #15 : Сентября 11, 2019, 12:12:24 pm »
I.V. Istratov
Problem of “Synclinal” Oil
The author supports V.A. Karpov's proposal that geology, tectonics, and oil and gas occurrence of negative structures (synclines, troughs, depressions, lateral and deep seated parts) should be studied in both old and new promising onshore and offshore petroleum provinces
И.В. Истратов д-р геол.-мин. наук РГУ нефти и газа им. И.М. Губкина,  кафедра теоретических основ поисков и разведки нефти и газа профессор ivistratov@mail.ru
"...ловушки антиклинального типа будут выявляться и в дальнейшем, в первую  очередь, в труднодоступных и малоизученных  на нефть и газ территориях Восточной Сибири,  в акваториях Черного, Охотского и арктических  морей."
Будут, но когда? И это будет  в труднодоступных и малоизученных  на нефть и газ территориях... есть же места и подоступнее...
“Synclinal” oil problem
Karpov V.A.Написать письмо автору1
1 “Subsoil use XXI Century” magazine
Hydrocarbon exploration everywhere and always (with rare exceptions) focuses primarily on positive structural forms. At the same time, structural stage of exploration is almost complete in many regions. Denial of the possibility of wide oil accumulations development in negative structures is based on the consequences of the buoyancy force influence. However, in the course of tectonic development, other types of energy arise, which markedly larger than the effects of gravity field. The major factor affecting HC trap genesis is the fault. The same faults are often control anticlines and synclines; so the paragenetic association of positive and negative structures divided by the fault is observed. And the negative structure was formed in the last phase of tectonic movements activation. By that moment, the main accumulations were already formed; and emergence of the negative structure caused transformation of the original accumulation with the formation of secondary HC pools near the fault, and they are situated at different depths. HC traps associated with tectonites are of particular interest. The key features of these accumulations are their simultaneous formations and fluid filling in the last phase of fault activation. Success of hydrocarbon exploration and prospecting is 20 to 40%. The main reason is in the fact that much of HC is associated with negative structures. The anticlinal paradigm should give way to the tectonic paradigm, which provides for a new direction of geological exploration: searching for HC accumulations within negative structures that can control sufficiently large fields. The success of HC exploration can no longer be increased by improving the methodology, introducing various innovations, if one continue to drill positive structures not moving towards direct mapping of HC accumulations regardless of their structural behaviour, and using various "direct" technologies.
« Последнее редактирование: Декабря 24, 2019, 05:29:20 pm от Тимурзиев Ахмет Иссакович »
« Ответ #16 : Сентября 29, 2019, 12:00:27 pm »
Е.В. Лозин (ООО «РН-БашНИПИнефть»), д.г.-м.н., Л.М. Рачева (ООО «РН-БашНИПИнефть»)
Детализация строения постседиментационных грабенообразных прогибов на платформе с помощью современных сейсморазведочных данных
https://oil-industry.net/Journal/archive_detail.php?ID=11775&art=234224
"В статье выполнен анализ новейших сейсмических данных, полученных при детальных сейсморазведочных работах в районе развития Тюйского, Восточно-Тюйского и Биавашского постседиментационных грабенообразных прогибов («малых грабенов»), выделенных ранее в пределах Республики Башкортостан на северном склоне Башкирского свода и в Благовещенской впадине. Нефтепоисковый интерес области рассматриваемых «малых грабенов» приобрели вслед за открытыми в 60-80-х годов ХХ века на юго-восточной окраине древней Восточно-Европейской платформы новыми зонами нефтегазонакопления, контролируемыми конседиментационными грабенообразными прогибами в терригенном девоне. В отличие от последних, постседиментационные грабенообразные прогибы распространены по разрезу от рифея-венда до отложений среднего карбона (верейского горизонта), что отвечает их геологической характеристике как постседиментационных дизъюнктивных структур. Показано, что интерпретация сейсмической записи свидетельствует о поэтапном развитии постседиментационных грабенообразных прогибов. В рифее-венде и верхнем палеозое полурегиональные постседиментационные микро-грабены возобновлялись при активизации тектонических фаз как четко выраженные дизъюнктивы, морфологические черты которых ослаблялись вверх по разрезу. На последнем – верейском – этапе сформировался неширокий (2-3 км в ширину) пологий прогиб с дизъюнктивным западным и флексурообразным пликативным восточным бортами. Нефтеконтролирующая роль постседиментационных грабенообразных прогибов пока доказана лишь фрагментарно, но новейшие сейсмические данные позволяют детализировать их строение, динамику их развития и влияние условий их поэтапной трансформации на формирование потенциальных ловушек углеводородов.
В статье рассмотрены методические приемы, позволяющие использовать возможности современных сейсмических пакетов, в том числе для получения информации о геоморфологии полостей постседиментационных грабенообразных прогибов во времени."
Есть нечто общее с проблемой "синклинальной" нефти...
« Последнее редактирование: Декабря 24, 2019, 05:29:39 pm от Тимурзиев Ахмет Иссакович »
« Ответ #17 : Ноября 01, 2019, 05:22:15 pm »
В четвертом номере журнала Недропользование-ХХ1 век в дискуссионном клубе опубликована статья А.И. Тимурзиева «Состояние ТЭК России и официальной нефтегазовой науки, определяющей направления ГРР в стране» (http://naen.ru/journal_nedropolzovanie_xxi/arkhiv-zhurnala/2019/4_tekhnologicheskiy_proryv_k_effektivnomu_nedropolzovaniyu/), где делается вывод о том, что «…лидеры органического учения признались в том, что Губкинская парадигма развития нефтегазового комплекса себя исчерпала, страна осталась без научного обеспечения ГРР и оказалось беспомощной перед вызовами современности.». Трудно с этим согласится, когда добыча и приросты запасов УВ растут (хотя конечно же хотелось бы иметь больше открытий), когда представители неорганического направления пока не имеют ни одного случая практического достижения, подтверждения справедливости результатов своих научных изысканий, когда все «трибуны» (совещания, конференции, журналы и т.п.), используемые «неорганиками», не приводят к заметному увеличению их сторонников.
Многое в этой статье спорно, но обсуждение поднятой Тимурзиевым А.И. проблемы требует отдельного разговора. А пока «синклинальная» нефть ждет своего открытия, в т.ч. – «неорганиками», учитывая, что объявлен новый этап в недропользовании, когда внедрен заявительный принцип, когда судьба минерально-сырьевой базы компании, региона в руках местных (и нанятых ими) геологов, когда любая компания (любой геолог), обладая соответствующими ресурсами и знаниями, может искать и находить нефть в любых благоприятных для нефтегазонакопления горно-геологических условиях.
« Последнее редактирование: Декабря 24, 2019, 05:30:26 pm от Тимурзиев Ахмет Иссакович »
« Ответ #18 : Декабря 16, 2019, 02:46:50 pm »
Итоги V конференции «Технологии в области разведки и добычи ПАО «НК «Роснефть» 2019»
https://oil-industry.net/pdf/2019/11/076-077RNconfer.pdf
"Общий тренд на еще большую технологичность в отрасли обусловлен тем, что так называемое «время легкой нефти» прошло. В России это связано как с глубиной залегания самих углеводородов, их составом, так и со спецификой регионов, в которых ведутся работы."
Это связано не только и не столько с глубиной залегания углеводородов, а с тем, что антиклинальный "подчерк" не истребим среди геологов...
« Последнее редактирование: Декабря 24, 2019, 05:31:01 pm от Тимурзиев Ахмет Иссакович »
« Ответ #19 : Декабря 24, 2019, 04:15:11 pm »
В Казахстане определят нефтегазовый потенциал слабоизученных бассейнов
http://www.angi.ru/news/2877523-В-Казахстане-определят-нефтегазовый-потенциал-слабоизученных-бассейнов/
"Особое внимание будет уделено развитию геологической науки. Упор будет сделан на научно-исследовательское и аналитическое сопровождение региональных поисковых и разведочных стадий."
Может и нам можно будет оттуда взять...Или им дать...А еще лучше: вместе, хотя бы по Прикаспию, где могут быть продуктивными не только положительные структуры...
« Последнее редактирование: Декабря 24, 2019, 05:28:05 pm от Тимурзиев Ахмет Иссакович »
